I have a master cylinder issue in my Sno-Cat. Oddly enough it uses the same general casting as a 60's era chevy pickup. Looks like this:
Normally I wouldn't bother to rebuild one, master cylinders are usually cheap. A 62 chevy pickup has dual 1 1/8" bores, one for clutch, one for brake. A C60 has dual 1 1/4" bores. Mine has one of each which is making finding a new one difficult. I haven't found an OEM version, this was an industrial variant. There is some pitting in the bore and a bit of a ridge. How much honing can these things take before the seals can't take up the difference? Any advice on the honing? I see both 3 stone hones and dingle ball hones available, any preference? I am thinking a 3 stone hone. The Lisle comes as a 240 grit, some others have multiple grits with lousy reviews. There is really nothing to it in theory, a spring, 2 seals, the plunger and a snap ring. I just need to find the right rebuild kit, already found the 1 1/8" side. Any advice would be appreciated.
