12v AC compressor aftermarket kit.
Similar ev compressor are high voltage, some might even be 3 phaseIs this the type of compressor the EV's are using?
Other way around. Compressor is 600 watts, 60 /70 amps, it says.Th3 compressor is only 30W at 15A. So the blower must be sucking the juice.
Does that math work on DC? I know it does on AC. I size the generator needs based on that math.The math doesn’t work out anyways.
Power=Volts x Current
So 30W=Volts x 15A means that it would need to run off of 2 volts.![]()
It’s still good though!Can't have Pie anymore. Too much sugar.
