Good morning,
Newbie here. Know nothing about engines. 1975 Chevy k5 Blazer V8 350 has been sitting for a few years without being started. To get it started i have a new battery, I checked the engine oil level and topped it up and in the carbeurator float I added gasoline to get it to start and engine sounded fine. Vehicle has been parked inside a dry garage the entire time with no temperature control/
After I started the vehicle I had to drive vehicle out of garage due to so much exhaust (no smoke) down a bit of a hill maybe 10 feet . Left it running a few minutes. Then had to reverse back up hill into the garage. I may have left the parking brake on while doing this. So truck wasn't reversing and I was giving it some gas. Realized the parking brake was on and released it then was able to reverse back into the garage which is level.
So after stressing out the vehicle there was some burning smell and bit of smoke from the area where the spark plug wires are.
So, did i damage something? Should I even try to drive vehicle after this occured? Concerned about overheating the vehicle.
The engine does leak oil slowly over time , from where I do not know.
I plan on starting it again next week and driving it a bit to see if the smoke returns.
Thanks for your help!
Sylvia
Sylvia
