Working on my Dodge Cummins and installed the PSC remote reservoir kit.
Poured a quart and a half fluid in and have it leak on the ground.
Turns out there was a gap between the pump body and reservoir housing - right at the bottom.
Turns out one the bolts hole on the back of housing didn't line up. When the bolts where installed, it forced the reservoir down therefore causing the gap. I found this out after I hammered on the reservoir for a half hour trying to close the gap.
I slotted the hole with dremel tool assemble the pump and reservoir again and pressure tested it.
Removing and installing the power steering pump is a PIA on a Dodge Cummins.
