Spare tire holder truck
mnstrburbon
Buena Park Ca
Spare tire holder that mounts underneath factory style it swing's down and spare comes out. Dont know what its worth 50.00 plus shipping
I will get some posted tommorow it currently has a 31 or 33 11.50 or 12.50 wide on it. it has a peice of all tread to allow for a bigger tire it is like a swing or cradle holds tire against frame or bed floor. Like a new truck only no cable and crank a lever to drop it instead.
i found this page 32 bottom right all the stuff that is faint not heavily highlighted is what it is. It is all complete and working.
http://www.lmctruck.com/pdfcatalogs/pdf/cc/CC06.pdf
Pics if you need something different let me know.
release mechanism
Yes they do they added the all thread to adjust for the wider tire im guessing the factory ones where probably shorter. I have not seen one of these before if you need a different pic let me know ill open it tommorow and take a pic of the tire on the ground so you can see how it works.
that sounds good. my guess is there is a piece of all thread in the center with a wing nut to hold the wheel to the spare tire holder? what do you think it would cost to ship it?
There is nothing in the middle to hold the tire might want to refer to the link and diagram to see if something is missing or needed.
I just checked the lmc link and the part 7 is missing on this set up so one would need to be made or bought and all the hardware wich should be easy enough to find.
Make offer want it gone.
here is a pic of it off the truck and it had a 33 12.50 on it.
