Can't get it out of the driveway...sputtering so bad when i put it in gear. Idles fantastic though.
No, it's not that, but thanks for the input. I got metal lines.I've been there! Maybe you upset the fuel pressure. Did you accidentally move a fuel line and rupture it? "Undo" the flare at the end of a hard line to cause a poor seal? Any smell of too much fuel or visible leak?
Go back to where it was before you adjusted it and see what it does.
When you set the timing, did you plug the vacuum advance hose? What's the timing set at?
And only do one upgrade at a time. That way you know which one went wrong.
I plugged the carb port, not the vacuum advance hose...sheesh..maybe I should have
Plugging the port on the carb is correct.
Sounds to me like it is really retarded(I have been told it is politically incorrect to say that). Also check that the TDC mark is correct with the number 1 piston location. I have seen cap loads of balancers installed with the incorrect locator position.
