Anyone run one? I kinda wonder if I should run a couple of them. I'm redoing the exhaust in my truck (headers, 2.5" pipe straight through 2.5" mufflers) and I'd like to keep from starting any fires.
Now, it has occurred to me that I ran for many years with essentially this same setup with no issues (well, it had Flowmaster 40 series mufflers on it for most of the last decade but they're still pretty much straight through).
There have never been any catalytic converters on this truck, 49 state cats didn't start until '79 for trucks with a GVWR over 5200 IIRC.
Any comments or ideas?
byproduct of combustion is water and carbonmonoxide,so it should just be that coming out the end of your pipes.even with 4 ft of exhaust and cherry bombs with downpipes i didnt have flames coming out.just loud as hell.if you go into high fire areas,you could make removable tips for the ends of your exhaust as was stated already.then you are fully covered and dont have it in the back of your mind nagging you that you may cause a fire.
