spark plug brands
78Suburban
Georgia
AC delco R45TS spark plugs are correct for my truck.
the local hillbilly Advanced auto sold me Autolite 685 plugs and told me the same thing. after comparing them to the correct ones that are in the truck now, my new autolites look a little different (the threads go further and the ceramic part is shorter). So how do I correctly cross reference them? Will the new autolites work in my truck, or do I need to go back to town and swap them in on the AD delco's that I know are correct?
I'd go swap them for AC's. I try and only use AC's and NGK's.... They seem to work the best.
I like autolite plugs and use them if I cant get AC Delcos on sale. But I usually use #145s. They are a heavy duty plug.
I looked up that number he gave you and I saw it listed as a light duty OEM plug for your Sub with California (Smog) application gapped at .060.
I think I would take them back and get some AC delcos. Make sure the hillbilly gives you the right # :D
http://www.autolite.com/products/ You can look up the plugs in their cataloug
when to hillbilly, swapped for the correct AC Delco plugs. The truck runs SO much better now. the old plugs had doo doo on the electrodes :crazy:
i like the champion truck plugs. they seem to work pretty good in my 350. but, i havn't really used anything else.
champions been living off their name for years... put one next to an AC, they look cheap...
Rumor has it that autolite is, and has been for awhile, making NGK's plugs and Delco's as well.
I won't suggest it's fact, but wouldn't be surprising. Delco has been trying to save money on their parts for years. (although you can't tell by pricing usually)
Haven't been able to find anything authoritative on the subject so far.
Last set of 8 autolites I bought, 2 were bad out of the box, but as fragile as plugs are, just dropping the package during shipping could have caused that.
