Spark plug recommendations?
In my underwear
Administrator
Author
CO
What kid of spark plugs do you guys recommend for a stock 1991 350 TBI?
cant go wrong with good old acdelco . . . . I been running them for years . . .
even had one still fire after it blew out the metal from rust thin out .
Agreed
I always run OEM plugs for whatever the make is.
Autolite platinum.
Thats if im not using ACs
BOSCH are the worst plugs to put in a newer Chevy..especially the platinum ones..I've seen engines skip worse when those were installed many times,and "cured" when AC plugs were put back in..
I have to admit I've tried the fancy expensive spark plunges and found that they do more harm than good.
Learn from my mistakes and stick with the OEM.
