lak2004
Well I changed my spark plugs last time and was wondering if you guys could tell me what all the stuff on them means? I have no clue here are pics:
I see some tan on all of them, I wouldn't be worried about rich/lean.
#2 is pretty bad (oil fouled). You could have a really bad valve seal but its more likely a ring. I bet if you did a compression test #2 would look pretty bad compared to the others. At the very least I would replace that one plug to keep it going until you swap this motor out.
damn thats what I was afraid of, i am hoping to swap in a 6.2 but I am not sure if that will happen yet, if not guess it is time for new heads or get them rebuilt at least. I will try to get a compression test done tomorrow depending on how the weather is. Thanks!
Hit that #2 plug with a brass wire brush and stick it back in. When it starts to miss again pull it out and wire brush it again. The motor in my Dad's Jeep CJ5 I used to DD has similar problems with fouling 2 of its plugs like that. It has been that way for years and will continue to be that way till he can afford to get the motor overhauled.
His CJ5 burns a quart of STRAIGHT 30w oil every WEEK if driven daily (250mi/wk). It also runs rich so it can foul out the plugs pretty quickly (1-2 mon). The motor still runs like a top as long as the 2 plugs aren't fouled, and it runs like a raped ape.
If it just fouls one plug every now and then don't sweat it. Run it till it goes or till you have money to put into getting it done right.
The rest of your plugs look fairly normal for a carb'ed engine with some miles on it. Hit them with a brass brush and stick them back in too. I used to pull my plugs every 3-4 months on my K5 and clean them and reinstall them. The Qjet ran rich and it burned a little oil. Now that I have FI my plugs come out the perfect shade of Tan every time.
