speakers behind seat?
trailblazr81
Hollister, CA
Has anyone put a woofer box behind the seat of a pickup? I have a 73 K20 that I plan to put in a CD player, 6x9's in the doors and an amp under the seat. I have some 12's from when I had a 81 Blazer. Can a box be put behind the seat? Im 6'1" o I need the seat back as possible. Im no longer a kid so I cant o the steering wheel in the chet thang no more. Any idea's???
cramming them in, i think 10s are as big as you can go in a pickup without modifications to the cab
as far as i can imagine, you would have to build a custom box to fit 12s... modify the ledge thing to allow for the speakers to fit (drop it down so the 12s mount lower)
i suppose you could build a box into the bed area, like mount the 12s flush on the existing rear panel of the cab, then box in behind them and knotch the bed front to allow the box... but thats a LOT of sheet metal work for speakers
other options are custom center console (and bucket seats) with the speakers in the console
A box can be build for it, if you have the cash. It's just a matter of air space in the box. It's not going to sound great either, but only because of the confined space of the pick up cab. I agree with the previous post. Cut out the space between the cab and the bed and get a tanou cover. Rubber gaskets are made for those jobs to fit between the bed and the cab. AND, with all that air space in the bed, it'll sound good too.
A box doesn't have too be perfetly square. A friend has a custom built box that go's behind and under the seat. I was pretty suprised at how good it sounds It's a chambered box, kind of like a bandpass box with the ports firing out from under the seat.
I have the same style truck, and I put 6x9's behind the seats. I used ready built boxes, and they just sit on the bottom ledge. I cant hear any high frequency out of them, but it helps with the mids, and low end. I didnt want woofers, so for me it worked out OK.
Yeah I have 2 of those I put my 6x9 speakers in... I got the boxes from Circuit City for like $30.00 for the pair... With the seat all the way back it touches the front of the speaker.. I can tell a difference in sound when I lean the speaker forward... But I am not interested in a high performace stereo in my play truck.. With a Kenwood deck,200 watt EQ/amp, 2 Pioneer 6x9 's. and a little dual 8inch woofer speaker box with built in tweeters behing the seat it is just enough to here over the motor and exhaust :thumb:
I built my own box to fit two 10's behind my seat. I am only 5'8" and I wanted as much space as possible so my seat is moved forward and the box is sorta contoured to the cab, but I think that most 12 inch subs are too deep to stick back there. My subs line up with the small of my back and the passenger's back, and my amp is recessed into the box in the middle. Nice back massager, I must say.
