i made some notes:
i've made a few notes for reference:
i got the Harbor Freight Trans jack, #60234, which did pretty good. My only complaints are i wish the adjustments for the support arms were underneath the saddle rather than on top-----so you can adjust them easier when the trans is on the jack. And, the tilt knobs i thought are too high up such that there can be interference between them and the trans depending on what angle you need.
As seen here, IF you are going to the roll the trans under the car with this jack, then you need minimum 26", UNLESS you tilt the trans forward; In that case, you might be able to get by with as little as 18". If you slide the trans under the car w/out the jack, and then put it on the jack while underneath the car, then you could also get by with less height, although i'm not sure how you could do this unless you had a helper?
i underestimated the amount of height needed, using only ramps under the rear wheels, but i still got it in by tilting the trans forward as necessary AND lifting the rear axle by about 1/4"----i think the new pan may be a little deeper than stock?
i am not totally sure on the actual size of the hardware, but these at least are the wrench/socket sizes:
NOTE these are for 2WD truck:
Driveshaft 7/16"
Cooler lines 11/16" flare = fittings that go into the trans, although could be 5/8" flare
1/2" flare = fitting that screws into the large fitting that goes into the trans. as well as fitting that screw into radiator trans cooler.
Kickdown cable retainer = 11mm
torque converter to flexplate = 15mm if later lockup models, 9/16" both bolt and nut if non-lockup or pre 78?
Transmount to crossmember = 5/8"
Transmount to Trans = 5/8" However, later models (after 77) and lockup units may take 15mm
Crossmbember to frame = nut is 11/16", bolt is 5/8" There are 8 total
For the upper crossmember support to main cross member = three 9/16" nuts and bolts.
Bracket for TCC wiring plug = 15mm (note, only applies to lockup models)
