joshkbomb
This post is long, but is a few questions that have managed to build up over the past few weeks that you guys may be able to help with.
1. My speedometer cable makes a clicking sound all the time (since the cable was new a year and a half ago). I've figured it's slightly too small and slides out the back of the speedometer just enough to start clicking but still operate the speedometer. I figured this out by re-seating it a couple times and the sound goes away for a day or two. Is there some kind of spacer I can put on the other end at the transfer case to 'lengthen' it, or should I just get a new one (pain in the but)?
2. I have a leak coming down from underneath the dash onto the driver's side floor beneath the emergency brake. I've searched and the only explanations I can find are a plugged drain hole under the panel between the hood and windshield (what's it called?) and a leaking windshield. My windshield isn't leaking, so it must be the plugged drain hole. The problem is I can't get my windshield wiper arms off to get the panel off and look for this drain hole. How am I supposed to do this? I've pried with long pieces of metal for leverage but neither has come off.
3. My base timing is 4* before (retarded?) and I went to fix it but I can't reach the distributor loosening bolt. I think there's a special wrench for this but I wanted to ask if there was some trick to this before I went out and bought a tool with only one purpose.
4. When I was checking the timing I noticed that when I plugged the ESC back in, the timing shot to 20-24* before (guess because it was beyond the scale). Is this normal/okay? Oh, and the engine was at operating temp at the time.
Whew, that was a lot of stuff. My truck is an 87 Blazer with a 350 and mostly stock (msd ignition coil is all the non-stock). I've been going through everything recently because with gas prices being what they are ($100 for my last tank and this is my daily driver) I think I can do better than the 16.5mpg(very light foot) I've been getting. Thanks for any help you can give!
I was bored...and cant go to bed yet,wife an kid are watching Mary Fing Poppins
So here.
