GalDemSuga
I just pulled the mechanical gear from the top of my NP 241C Transfer Case. Its has 42 teeth on the gear and the speedo is reading 68 mph when I'm actually travelling 60 mph. Where can I get the gear to correct this?
You'll need 47 or 48 teeth. If one of those isn't available, you'll have to change the drive gear, which would mean pulling the tailshaft off the T-case.
I got my speedo gear for a NP208 transfer case from the link below. They also sell ratio adapters if you want to consider this option.
http://www.transmissioncenter.net/s...______va.htm?gclid=CIHhkMaDwaMCFQE-bAodKiIJhA
