One of the old parts stores I worked at had a dusty old wooden box sitting on a shelf in the attic--I opened it up and discovered it was a case containing several compartments,full of gears for those speedometer gear box things..it was labeled "Stewart-Warner"..the inside lid of the box had a calibration chart with all the rear axle ratios and transmission options,tire sizes,so you could choose the right gear combination...
Probably the last ones available to the general public..
I swapped the gears on my '72 K5 's speedo gear box with two from that assortment,to make the speedometer read correctly after I changed tire sizes and put a SM465 in it in place of its original TH350..
Looking back,I should have taken that box home!..boss never knew it was even there,or what was in it,or what the gears were for until I told him..
