Speedometer cable not working
k51977blazer
Cocoa Florida
I have a 1976 k5 blazer turbo 350, speedometer does not work I checked the cable and have movement my cable was connected to this part I never saw before I disconnected that part and connected the speedometer cable directly to the transmission still have no movement any one have any ideas or what that part is called
Spicer speedometer correction. Clean it up, there should be a stamped number on it.
Mine has a .20 correction, makes the speedo 20% faster than it really is
th
The gear inside the th350 maybe stripped
hook that mess back up to the cable and slowly speed it up with a drill to test everything else in the system
Not usually!
Take it apart, its already broke
Cool, you're half way through trouble shooting!
and since your truck is a "K" model, the speedometer is in the transfer case. Unless you have the random 2wd Blazer
No I have the 4x4 I’ll have to remove it tommorow
and see I’m sure someone makes the kit thanks for the help
I put everything back together made sure it seated and tried again still doesn’t work
Did you see the post by @sweetk30 above?
Either the gear inside the output is stripped, or maybe the end of the Speedo cable is no longer square
if you have a ratio box and then cable there is the plastic adapter sleeve like i linked to make the round -tab go to the square drive for the cable .
i ran my truck for years with no speedo until i found this missing part was all that was needed . . :doah:
i have also seen a few drive gears with stripped out square inside them . you need a new / used one then and match it to the letter stamped on the side of the body .
this part here . right side you see the 4 flats crimped in to it . inside they can go round and not drive the speedo cable.
b6265b39-a4dd-4a7d-a2d3-0da16fdf185e-jpeg.350718
