Speedometer problems and questions abound here. Anytime anyone changes gears, tires, they have to deal with inaccurate speedos.
OK, that sounds like a wardrobe malfunction......
Anyway, when I went to 12.50/33s on my '89 F250, I was able to find some gears for the 205 that put me back real close.
Surprisingly enough, my worst problem is with my M-class Mercedes. The speedometer is fairly accurate, but its just super hard to read. The numbers are so close together, the needle is about 3-5 mph wide.
My solution and the one I have recommended here, is a GPS on the dash or windshield.
I like it. I seldom use the navigation function, but the speedometer and trip odometer function are nice..
But, its a pain to move between the three vehicles. And buying three Garmins just to get accurate speedometers seems excessive even for me.
So, I have ordered one of these.
http://www.amazon.com/Head-Up-Displ...stallation/dp/B005X4QCAA/ref=cm_cd_ql_qh_dp_t
I got it as a test to see if I like the HUD. If it works and I like it, I may spring for a slightly more expensive one with a trip odometer.
It won't help folks who have shift problems due to an inaccurate VSS, or someone who just wants their stock unit to be right.
But its cheap and simple if you want to know how fast you are going no matter what tires you are running.
Its tentatively due in tomorrow. If it makes it, I will probably plug it in and toss it on the dash on the way home.
Then I will probably mount it in the truck, although I may leave it in the car for a while since its my DD until hunting season rolls around.
Eventually I intend to hardwire it in to a switched power source. I will post my impressions after I try it.
