Hi All,
The other day I replaced the busted speedometer/odometer cluster on my 89 Jimmy with a supposedly working one from ebay. The install is quite simple, just the cable that comes from the back of the transmission/transfer case area, and a green/red two wire connector that should go to the ECM I assume. After putting it in, neither the odometer or speedometer works, and I get OBD 1 check engine code 24 (Vehicle speed sensor error).
I just did some searching on the forums, and some people mentioned the numbers on the odometer can lock up and to spray some lubricant in there. I haven't tried that yet, but I will. Also, before putting it in I spun the back part of it and verified that the speedometer did rotate. Any other ideas on how to debug? Junkyards/Pick and Pull isn't an option here unfortunately.
Thanks!
Thanks!
