OK I got ya, same procedure for '91, which I expected. There is another manual that covers VSS, which is emissions. Luckily I have that one too.
So my test procedure would be:
Turn key to "run". Test voltage on 824, use a sheetmetal ground. Something you KNOW is a good ground, not something suspected as a good ground. A lot of times I use the continuity checker to confirm, a lot of screws or surfaces have rust or paint, and can NOT be used as-is as a ground.
If you have no voltage there, page A-10 and A-11 in my manual show the fuse block. If you've got voltage to the heater/AC fuse, then apparently 824 should have power. If not, then you shouldn't have power windows either, that fuse is fed with the same power line as the heater/AC one.
Do you have an autozone close by? It would be pretty easy to see if the DRAC was working based on a scan of the ECM while driving, to indicate if vehicle speed is being picked up. DRAC CAN have problems and the truck still run, but since the ECM speed signal is the only easily readable output of it, it would be the easiest/fastest way to test.
There is another test mentioned. First, your service manual, under 8C-3, should have a page on "diagnosis of the speedometer system" which covers the DRAC. But its kind of vague. The emissions manual has these tests:
Clear codes
back probe across ckt 1233 and 1232 at PCM connector
Vehicle wheels raised, engine running in gear
voltemeter on A/C 200 volt scale
Does voltage vary from 0 up with RPM increase?
Yes: Problem is intermittent or internal transmission. (I'd think that could indicate DRAC too!)
No:
Disconnect speed sensor with vehicle still in air, running, in gear
voltmeter on A/C 200
Measure voltage across sensor
Voltage vary with RPM?
No:
Replace sensor
Yes:
Problem is Poor PCM connection
Poor connection at output speed sensor
Open CKT 1233 or 1232
Shorted CKT 1233
(I'd also add that again, DRAC is between the sensor and the ECM/PCM, so it could still be faulty!
