duanel
Registered Member
Okay I have a 73 blazer auto. 203 transfer case full time 4wd My speedo is off about 10 percent wich would be right since I have 285 75 16 so I was looking at ratio adapters at http://www.transmissioncenter.net/speedometer_calibration_______va.htm and see what I think I want but when I looked at my transfer case there already seems to be one there a stewart warner 1.2020x 666f r9 I took it off to see what effect that might have and it seem my speedo was now off about 30 percent under. so my quesrion is did it come from gm with the adapter or did one of the previos owners add it because they changed transfer cases or speedo gears and if I was to get another ratio adapter should I add a 11 over inline or replace it with a 30 over,
