Realized one of my hubs (originally on a D44, now on 10 bolt) are missing the "outer" o-rings. Not the ones for the knob, the larger of the two o-rings used that seals the outer portion of the hub assembly.
No idea if the later cheap looking GM hubs use the same pieces, so hesitant to use any part numbers in my parts manual to check GM stock.
Also need the metal washers to go under the hub bolts.
I found a post mentioning http://www.sixstates.com/ but their online stuff is painful to try and find anything in. Probably call them tomorrow unless someone suggests somewhere else.
Anyone happen to have part numbers for these, I assume I'll be needing the Spicer numbers, although GM part numbers might work, if GM still sells them.
Thanks!
Thanks!
