Spider Gears
hawglet
Hastings,NE
I have an '84 K5 with 400 small block,700r4, and 3.73 gears running 33's. I was leaving work and I got in to it enough to break the tires loose. They caught before I was through the intersection and about 1/2 block later I felt a big BANG, felt like someone assholed me, I stopped cause I have a bed u-joint and figured that was what it was. It wasn't, I'm thinking that it is the spider gears, driving down the road it makes a real loud clunking sound. Of Course I took it out of action immedately. I going to pull the rear diff. cover off tomarrow afternoon to check it out.
Thanks,
Greg Gayman
Hawglet
Stovie
[email protected]
(squinching with pain) good luck!
Keep the rubber down
The spider gears aren't spinning while the truck is going in a straight line. They're just along for the ride until differentiation is required. My guess is that you broke a tooth off of the ring gear.
Very common failure mode with the 10 and 12 bolt rear ends.
<font color=black>HarryH3 - '75 K5</font color=black>
<A target="_blank" HREF=http://ThunderTruck.ColoradoK5.com>http://ThunderTruck.ColoradoK5.com</A>
