spinning an IP dry
Mikey von
Burney, CA
I want to pre-oil my engine using my starter (no injectors installed). I have already installed my IP.
Is it ok to spin my IP over with no fuel (lube) supplied?
Why not get some hex stock and a drill? Easy enough to pull the vac pump and give her a good whirl rather than pull half the engine apart to remove the IP...
