spline count help.
LEEREED123
BFE, Ga
Well, I searched, but count figure it out.:(
Can anyone please tell me what the transfer case output shaft spine count is on my 91 with stock drive train?
thanks.
350, 700r4
also, where can I get a decent rebuild kit and a new shaft?
Output shafts, as in where the yokes bolt on to?
The t-case should be an NP241 and both outputs will be 32 spline.
thanks. yeah, the rear u-joint failed and drive shaft and transfer case shaft bent.(70mph when it happened.)
any idea where I can get a new one?
I'm sure somebody in your area has a driveshaft and slip yoke. Post up a wanted add in the parts wanted forum.:wink1:
