spline count??
shady
1 ton status
iowa
would an 88 v10 burb have 30 spline 8.6" diffs ?
is the 8.6" part right? 28 spline...:waytogo:
It's 8.5 but the use the same ring and pinion as the 8.6, only difference is the bearings. I did just learn they made a few of the 88 late models with 8.5" with 30 spline axles.
well I may have to pull an axle and count em I guess :dunno: I gotta rebuild the front outers soon. ill pull a front one then and count. I was just trying to see if it was an easy know thing so I could order everything and drive it to my local race shop for a gear change.
They are 28 spline for sure, I have a good set of axles if you need them, they are yours for the cost of shipping.
A GM dealership should be able to type in the VIN and tell you one way or the other. Tell them you are looking for a new carrier or axleshaft and casually ask them if it's the 28 or 30-spline version.
If that doesn't work, call Lester's Gear in Tulsa, OK (918)-834-3601
They seem to know all that stuff by heart.
4wheel parts used to actually tell you what was for your truck... now they just let you put your info in and still show everything they sell:rolleyes:
I think 28 sounds right from checking before.... I was thinking the 8.5 was the car 10b and 8.6 was the truck ones...
Chevrolet K5 Blazer Specifications - Colorado K5
coloradok5.com/specs.shtml‎
Jump to 1989 - The 1989 Blazer had new base and up-level grilles, as well as new ... Corporate 10-bolt axles were upgraded to 30 spline axle shafts from:D
thanks.. I forgot about that spec list
