Stomis
Professional Amateur
I currently have a 208 behind a sm465 in my truck. Since I am probably going to part out my truck I'm considering just keeping the tcase for my s10 build.
The tcase is an 87 NP208 that is behind a sm465. The input is a 32spline correct?
So I'm curious what its going to take to get this 208 to bolt up to an nv3500. Seeing as how its a half ton unit I can only assume its 27 spline output no?
Therefore I would need to swap my input shaft in the transfer case to accommodate the nv3500 (which i'm assuming i a 27 spline since its a half ton trans.)
O and as a side question: Anyone know what year s10s switched from manual speedo to electronic? I'd imagine it changed with the 2nd gen switch.
