There are 2 countersunk phillips screws that hold the case halves together, i'm assuming you have those removed? Also don't forget to line up the marks on each case half when you reassemble the case.
damn do i feel like an idiot...could have swore i had an open carrier, turns out it's a gov lock...
i called that one
and fyi next time http://coloradok5.com/forums/showthread.php?t=151608
i got a open carrier no guts if you need one. i think its 4.10 down . pm me if you do .
How far do you have to go? Your rear wheel bearings wont be properly lubed.
