Nate52
Registered Member
This is my first post - sorry if this has been covered in another thread.
I have an ‘80 K5 I’m working on and brakes are failing. The brake pedal is soft and the truck only slows down mildly with the pedal to the floor. The brakes worked fine a few months ago. Over the course of just a couple weekend rides to town they became so soft that it’s unsafe.
There are no obvious leaks (doesn’t mean it isn’t leaking, but it doesn’t look like I lost all my fluid at once.) there is fluid in the large side of the master cylinder but none in the small side. When I depress the pedal I can see the brake booster moving but the fluid level in the master cylinder doesn’t move at all when the pedal is pressed. I don’t have much experience when it comes to brakes so any troubleshooting advice would be great. Thanks in advance.
