Please don't take this personally, but this statement is completely wrong. If there is no torque going into the axle with a full locker (Detroit, Lock-right, etc...) from the driveshaft than it will be unlocked and have no steering drawbacks. I have a Lock-right and several guys in our club have full lockers also. There is no noticable steering difference when in 2wd between having the hubs locked or unlocked.
Many limited slips WILL make a noticable difference in steering with the hubs locked because it doesn't matter if there is any torque input or not as they always have the clutch packs preloaded the same way. I ran an Eaton Posi (spring loaded clutch packs) in the front for years and you could tell the difference between having the hubs locked or unlocked, though it was not dramatic.
Regarding some of the other comments, I also completely disagree that a spool or welded diff is somehow harder on axle shafts and u-joints than a Detroit, Lock-right, etc... Sure, there is some "play" with a locker but not like it will let a tire slip when under a heavy load to relieve stress on an axleshaft. If anything a locker would be worse as the "play" is really slop and can cause a big shock load when it engages..........ever drove a light vehicle with a Detroit on the highway? Ever heard the loud bang of a Detroit and feel the vehicle lurch sideways after you coast down a hill then give it a little gas to get back up the other side?
My turning radius isn't any different now that I have hydro-assist than before. Come on now, hydro-assist does not magically make the wheels turn more now. It does make it easier to turn and go lock-to-lock especially when the wheels are jammed in rocks and ruts.
And again, crossover steering does not make it easier to turn. The main purpose is better geometry, mainly so when the front suspension is crossed up you still maintain the ability to turn the wheels both directions. With stock steering the draglink is so short that when the drivers side suspension droops all the way out the steering box is turned to full-lock just to keep the wheels pointed straight and therefore it doesn't have any range of motion left to turn right.
