Spring Bushing Question
Subember
Registered Member
Bakersfield, CA
I bought a 4" lift kit off Craigslist for my burb and have a question. I believe the springs are rancho due to the name being stamped on the rear blocks so I have to assume the springs are too. I purchased a front bushing kit and am wondering about the fitment of the bushings into the eyes.
Should they need to be inserted with a hammer and block of wood? Or should I be able to push them in by hand? Shouldn't they be really tight? The springs are 2.5" wide and have a 1.125" eye on the shackle end. It's hard to tell because the shoulder of the spring has a chamfer in it. I'm questioning myself because there is a note on the bushings that if the eye is 1.25" then I need a different kit.
Also on the shackle side, which bushing goes where? Thick and thin shoulders on the bushings.
Thanks, Alex
