this is the spring pack clamp bolt that you broke.......sping pack tried to twist between leaves w/sideways force.....center pin's technical name is a tie bolt as it ties the leaves together and it could be loose let'n springs twist eaisly....did it spread the clamp or fan the leaves?
hmmm....sideload? could be just plain ole mechanical failure...grade 8 should fix you up...and there is supposed to be a sleve on the clamp bolt also, so bolt doesn't actually clamp springs but hold them aligned and slide as they flex
There is supposed to be a sleeve over the bolt, was it there before this happened?
All the spring packs (factory) I've seen had that piece, although I'm not sure how much they matter. If that wear is from the springs, then I'd say it matters quite a bit!
Perhaps they were removed, additional leaves or something in the packs?
I left the bolts/sleeves off after I put my Add a Leafs in, I know I should put them back in, just haven't yet. Only reason I didn't was because I didn't think to clamp the spring pack together to get them reinstalled. As it is now I couldn't fit the bolt because the springs are in the way.
Naw, I'm sure they are pretty much universal, from the wear on the bolt you posted already, I'd say the sleeves are a necessity if you can run them, eventually that bolt would have failed in the wear spots I'm sure.
