virgilh
well i have a few things that ill never use
a oem 14 bolt yoke 25.00
a 14 bolt open carrier 40.00
a set of 14 bolt spider gears 25.00
a set of procomp 6 inch lift front shocks 30.00
a front driveshaft out of a 80's ish truck 55.00
a set of dana 60 30 spline hubs 70.00
dana 44 short side axle's good seal surface good ears 25.00 ea
dana 44 long side axle's good seal surface good ears 25.00 ea
10 bolt axles ditto ditto long and short good seal surfaces 25.00 ea
serpentine set up for small block with all aluminum brackets pulleys and alt 125.00
edelbrock intake 2101 w/o egr valve used replaced with vortec heads and
new intake 60.00
14 bolt spring plates for the 14 bolt swap 20.00
a 4 inch block and u bolt kit for 1/2 ton 30.00
york compressor turns nice and pumps air 50.00
looking for anything ive been building chevys for 20 years and i no longer want to store stuff so asking doesnt hurt
theres more but this will start it
new intake 60.00
