wage92
Alright, so i think i have found a solution to my bad rear shackle angle. Right now i have custom made rear 52s (installed by PO), and when i put my shackle flip in my shackle is like straight up and down, and i understand it should be more like 45 degrees pointing back, or at least somewhat pointing back. So i think i have a solution...and that is to use 56" rear springs. But i have a few questions about this, from what i understand i can flip the shackle flips side for side and the front mounts wont have to be messed with, second, will installing the 56s get me any lift over the 52s? because if anything i need to lose a little lift in the rear to level her out. If they do gain me lift, could i remove any leaves to make it level?
and lastly, the 56s will make the axle offset because they are 26/30 center to eye, correct? can i fix this with an ez inch?
