Spring Measurments please
Merv
Minnesota
Lookin for someone to measure their springs. Need measurements from some 52 inch rear spring 4 or 6 inch variety. I need the measurments ,(that i have marked in the pic) so i can figure out what i need to get for my International.
There is the setup that is on there stock. Not sure if 4in is gonna be enough and i want enough to get rid of the block. So if i could get some numbers to compare that would be sweet:)
Edit: With weight on them would be the most accurate.
Front spring eye is 25.25" from the ground to the center of spring eye, rear spring eye is 23.75" from the ground to the center of the spring eye, center of spring arch is 18" from the ground to the bottom of the spring arch.
This is a 4" superlift spring with 35" BFG's. The actually way to measure a spring though is to flop it upside down with the spring eyes laying on the ground then measure from the ground to the spring pin. I did a quick drawing and this dimension is 7.5"
