45acpJr
I'm trying to get my 14 bolt ready to install and the last thing to do is reposition the spring perches. I understand the principle behind the pinion angle, but what I am doing is installing the axles and then I am lifting it later (it's a dd so I have to do everything in steps). When it is all said and done I will be running a 4" lift, what angle should I place the perches and also will it be ok to run before I install the lift?
