Spring Perch Width?
85k5mudtoy
Warrenton, Virginia
Are the spring perch widths the same from a K30 to a Suburban? I know the Blazers are narrower and require the perches to be moved on a 14bff but is it necessary to move them for a Suburban?
K30's are narrow in the rear, all others are the same.
Shock placement changes with models too.
Search is failing me today.
What is the 3/4 ton perch width?
The 1 Ton seems to be 42.5
