spring plates or ubolt plates
cybrfire
1 ton status
Iowa
Some of the most rigid plates out there. A flat plate alone won't get it done!
$45 for a pair. Just about any axle doable. If it isn't listed give me a hollar.
If you have an axle that has leaf springs mounted via ubolts, we can build plates for it! The most bizarre spring plate out there in a week or less right now!!!
That's the advantage of making everything in house.
We've already done them for as small as Stock Samurai axles all the way up to 2.5t rockwell and larger!
Just ordered one of these for a 14-bolt this morning! What diameter u-bolts do you recommend using?
Hrrrrrmmmm...wouldn't mind a set of these for Big Ugly's Dana 60 when we move the axle forward...
Lots of these in stock. Need a smidge of welding and they'll be on their way.
Guys these things are as tough as they come. Kert made a special set for my 14 bolt several years ago as I offset my center pin with F550 spring for truck pulling and they draw alot of positive attention due to the craftsmanship and beefiness when people look under my truck.
The only thing I would suggest is drilling drainage holes in the front prior to installation (mine always seem to collect dirt/water and are rusting on top even after etching primer and paint), but that is an EASY fix.
Kert, thanks for the awesome work.
