My springs are basically flat as they sit parked (unloaded) in the driveway, does this mean they are worn out? Can they be re-arched? Probably need new shocks as well as steering stabilizer since they look very old.
No. Stock springs sat flat or negatively arched, assuming you mean front.
Only actual test I can think of (that is fairly easy) would be to grease the bumpstops, and see if the springs hit going over speedbumps at moderate speeds, etc.
correct . stock front are tapered leaf springs and normal should NOT be re arched . or use std add-a-leaf kits . you need to use tapered leafs for them and not mix rear leafs .
subject covered a ton in past few months here and garage section .
now if rears are flat you got issues . severe overloaded and shot springs.
