I know there are easy enough options/solutions for covering up the hole left behind from going from an A/C equipped cab to a non A/C equipped cab but I am going in the other direction.
I’ve got two ( 85 K-5 & 83 K-30 ) original A/C cabs with all the correct OEM type components but both of the cabs has seen much better days ( and I no longer possess the patience and truly professional skill sets for body work ) but I also can get my hands on a very clean non A/C equipped 1988 R-3500 cab that requires no body work to speak of that I would like to use.
My question is this: is it as simple as carefully cutting a replica hole in the non A/C cab and installing all the components or is there some hidden differences that I don’t know of in each type of cab that makes this a bad plan?
I’ve considered the Vintage Air units but I would like to explore this option before I make up my mind on what to do.
Please advise with pros-n-cons and educate me on cab firewall differences that might be not easily seen.
Thanks, Tom
Thanks, Tom
