85mudblazin
Its all in how you build them.
My shaft is very tight and makes zero noise. The seam helps to cut down on this since it gives another edged to reduce the twisting force.
When you are done making it MAKE SURE that you get all the metal shavings and grinding dust out then use a good marine grease. I have had mine in the air slamming down a few times with zero problems.
I will always run square shafts from now on. Best thing since sliced cheese.
