CO Srw d60/14 bolt
Boydsk10
Registered Member
Four corners
Got a matching set of tons out of a 87-91 1 ton crew cab truck.
Front has a ARB cover, warn hubs, 35 spline inner and outer shafts, 4.10s, welded diff, has ORD 4 link mounts on it but will come bare unless somebody wants the 4 link and coilover kit too.
Rear has artec truss, chassis unlimited cover, yukon mini spool, 4.10s and set up for regular leaf spring with(not 1 ton spring width)
Dont want to separate, $1500 takes both
Coil overs included... Axle mounts, frame mounts, link arms... Panhard bar and frame bracket.
Shocks are king 2.5 believe its 250 over 300
