SRW studs on DRW hubs?
muddybuddy
1 ton status
Northern, VA
will the SRW 60 front wheel studs work on DRW hubs or do i need to get different studs?
idk but my drw hubs both say R like for right hand side at the end of the studs but they are on each side...see if you can get a part number for each and then see if they are the same..mabye in the dana 60 bible
i checked the bible and it didnt say anything bout studs, it just talks bout the differences between the stud holes in the rotors. they are different part numbers also, and i think the SRW studs are longer than the DRW studs, and id like the longest studs i can use.
ill check out the part number at napa tmrw, and post up.
i work at advance auto and they are different;) but let me know what u find out. im gona try to put the SRW studs in tonight and report back as well.
aha went to see my friend that knows chit. he wasnt there, off due to holiday for him:mad: so i talked to one of those mr know it all, the studs are not the same, so i need to know too. let me know what stud works on urs.
well i think u have to run the DRW studs on the DRW hubs because they are not hub-centric like SRW hubs. the studs are a little fatter where the rim sits to im pretty sure you can use DRW studs on a SRW hub, but not the other way around. the SRW studs are also longer
so with the srw hub, and 3/4 ton rotor. will the drw stud work? im confused.. cause stud isnt that cheap lol..
