stabilizer bar
gmcman
Red Deer, Alberta, Canada
I'm not sure if it's a stabilizer bar or sway bar or both but was wondering how many of you guys that use your trucks as DD's and drive a lot on the highway use the sway bar? I'm just installing a 6" lift and going with 35's and just wondering if it is legal to drive on the highway without the sway bar or if it is is it safe? How does it handle without it? Thanks!!
most everyone here removes it. it will help offroad for suspension movement. with 6" lift springs, they will be stiffer then the stock springs and you probably won't even notice it is missing.
