stabilizer link + bushings?
75K5
Michigan
Blazer is in the shop to get the suspension tightened up. They want to replace the stabilizer links and the bushings (pressed into the end of the stabilizer bar).
the problem is that they can't seem to find a part number or place that has it. can anyone help with part numbers or sources. it's a 75 K5, 4WD.
thanks,
Brian
pics please, any rubber bushings come with the shock. If you are talking about the metal stud on the axle side, stores should have those or ORD. On the tierod said, there isn't anything unless it's aftermarket wit a clamp on style mount and if so it's an aftermarket piece you need.
I used the Energy bushings. Definitely cut down on the noise and the steering felt better. The factory bushings had basically rotted away.
