I would be leery of using stainless bots on such a critical part--I tried putting stainless bolts on a friends Corvair ,his front axle beam rotted away,and he found a brand new replacement,and he grabbed a bunch of stainless bolts fro his work,which may have only been grade 2,and I popped 3 of them BY HAND with a 3/8" ratchet as we were instaling the beam!--I went to my bolt drawers and got some grade 8's and told him I would NOT trust those brittle bolts,stainless or not--its not like the beam would ever need to be unbolted again in our lifetime anyway...(sadly he died less than a year after we did that job,of heart failure,only 35 years old!
I've used never seize on things like exhaust studs,and they still always snap off 99% of the time..maybe it works better on spring shackle bolts,but since GM never used any when they assembled the truck,thats the only time we'll have to deal with seized bolts,when we remove them for the first time..for the 10-15 bucks each for a new spring eye bushing (included in the Dorman brand shackle kits),I just torch the bolts head & nut off them now and burn the bushing out,its not that difficult to get the new bushings in if you spread the spring eye open slightly with a pry bar and use a threaded rod and sockers to "press" them back in...and if you grease the bolts up good,chances are if they ever eed to be removed again they will come out no problem...
Know what I dont understand??--Why a ramp truck that carries 5 tons has the same 9/16" or 5/8" bolts on the springs that a 1/2 ton has,and they dont break!..you'd think they'ed increase the size along with the weight capcity??...shows how overkill most 12 tons are I guess...
