90RedBurb
Registered Member
Hey guys this is kind of a long post and hopefully i dont lose too many people. I have been having an intermittent code 42 problem that until this morning I thought that I may have fixed however it showed its ugly head this morning on the way to work. So while driving it will intermittently hiccup and set a code 42 and SES, while the SES light is on the vehicle will run crappy as if the timing is retarded (which I believe it is). If this happens on the highway it will stay on for a random length of time ( could be a couple seconds, could be 20 miles or anywhere in between). If it happens at low speed it may or may not cause the engine to stall. I was lead to believe it was the ICM however I replaced the distributor with no change. Following is the vehicle info and what has been changed over the last year or so. Some of this was hunting the code 42 and some was just maintenance items and or potential future problem points.
1990 V1500 suburban 5.7/700r
Parts replaced/ diagnosis attempts:
New distributor with ICM
Another new ICM that I had in case the new one in distributor was faulty
New AC Delco CTS
New vacuum lines where needed
Cleaned IAC valve then replaced IAC valve
Thoroughly cleaned and rebuilt throttle body
New AC Delco CR43TS plugs
New Plug Wires
Checked timing (set to 0 with EST connector unhooked)
New Injector Pigtails (old ones where in rough shape, partially melted assuming from backfire of some sort before purchase of vehicle)
Tested knock sensor/ESC module
Changed computer
In the last week I have plugged in my auto xray 7000 and watched live data and everything appears normal ( i think, integrator and BLM started at 128 and dropped to 108 and 114 but i did find a leaky injector oring and repaired that, have not plugged scanner back in to see if that changed) however I have not had it on the system while the code 42 was set and SES light on. I ran through the code 42 Flow chart multiple times and land at different points each time depending on the intermittent problem. However I went to the junk yard and picked up another computer and put my Calpack/Prom in it. Problem persisted. Checked est wiring and found no problems with it. Then I tried to change proms and this is where im starting to get very confused.
From what I found online:
ASDZ – 1989 LO5 5.7 MD8(700r) auto GU2 axle code
ARJT – 1991 L05 5.7 MD8(700r) auto No axle code info found
Junkyard computer and my Calpack/Prom(ASDZ) – No change in symptoms
My Computer with junkyard Calpack/Prom(ARJT) – popping and missing for first 30 seconds on cold start evertime, no SES or 42 for 2 days of driving then problem came back this morning.
Im not sure what to do or where to go from here on diagnosis. I don’t have another ASDZ prom to try to know if the prom is really the problem or what. Also not sure why the junkyard calpack/prom causes popping and missing on cold start.
If anyone can possibly give any insight on possible places to go from here it would be greatly appreciated as im rapidly becoming discouraged. I really thought after the prom swap and no SES for 2 days that I may have been on to the problem but now I don’t know. I have been reading posts like mad trying to come up with a solution and havent yet. I was just reading a newer post in the suburban section here about a member with a similar issue and it was advised to check the section of engine harness behind the distributor so i will pull the distributor tonight and see if i can find a problem ( ive checked it before but maybe not thoroughly enough). Any other advice would be helpful. If you made it all the way through this and didnt give up on me thanks! Also i was going to post this in the 73-91 suburban section but maybe because im new or dont have the premium membership yet i cant? im not sure
New AC Delco CTS
New Plug Wires
Changed computer
