BigOrange90Jimmy
I have an '86 K10, and I'm replacing the u-joint on the rear driveshaft at the transfer case. The joint I'm replacing is the original, so I've heated it to melt the plastic retainer that GM used. The problem I'm having is finding a replacement. The joint that Advance calls for is entirely too large.
The measurements that I've taken are as follows:
Inside yoke-to-yoke - 2 9/16"
Cap diameter - 1 1/8"
Internal lock style
By those measurements, it's telling me I have a S44 or GM 3RL u-joint. Am I right and their computers are wrong? The joint size they come up with is a Moog 534G, which is entirely too large.
Internal lock style
