rayfin
Registered Member
- Joined
- Jan 3, 2016
- Posts
- 97
- Reaction score
- 21
So anyway starters grinding. Running 97 GM mini starters. Worked for a while and then grinding again. Tried adjustments, shims, new starters etc Then I found the problem. If I put my starter bolts in a drill I noticed they were bent badly. Probably from over-tightening. Replace the bolts and with no shims the grinding went away. Just an FYI.
