Okay this is getting old with my 83 6.2 . I will try and make a long story short . Last week I went somewhere and I parked for about 25 minutes . I cam out and she wouldn't start . Acted like the batteries were low on power turned over slowly . Let it sit so the engine would cool down and the glow plugs would come on . They did and it started but slowly . I took the batteries in twice to NAPA and they tested fine . Okay so I took the Alternator off and hauled it into O'Rielly's was charging but no amps. Got a replacement . Thought problem was fixed .It turned over slow but figured they would charge up and be okay. Drove about 15 minutes went to Walmart was inside 15 20 minutes and you guessed it turned over to slowly and no glow plug . Cooled down got the plugs and she turned over slowly but fired up . Okay I am now guessing either cables or starter . I replaced the starter 2 years ago and I know diesels are hard on these sytems so I am wondering instead of a direct drive starter if I should go with the newer High torque starter . I have heard I would need to buy a new support bracket . What do you think is the best way to go here . also would it help upgrading Alternators to something higher than the stock 78 amp . Also I have 2 800 amp batteries .
