The only time the ign terminal on the solenoid is "hot" is when the switch is turned to start the engine.
What wire is the "new" distributor you installed connected to? If you ran a new, heavier wire like you needed to, it should go to a fuse block terminal that's only "hot" when the ign switch is in the run position.
Use a test light to find that.
